ebay wideband.
sy112
holy good deals for the guys who can't build their own Batman :eek:
if this really works then i'm all over it. anymore info for the technically challanged would be appreciated.
how would you get the WB to log on our dm/tl setups, if it's designed to read out on the little box? yes, i know nothing of how these work........yet
Methuselah
This is better than the DIY WB, it provides a simulated narrowband signal so you dont need another sensor bung. This particular one uses the much cheaper Bosch sensor as well (techedge can do this but its an expensive kit).
________
FORD MODEL C SPECIFICATIONS
sy112
but seriously guys, i know the patch for WB was designed for the DIY kind, so will the patch work with this one with TL. Cause if it will then the check is in the mail, so to speak. I need WB tuning damn it :D i'm thinking about the 250 model cause I won't need a LED read out if I am data logging on my TL.
Methuselah
THEMADTYPH00N said:
Whats the difference between the bosch sensor and the NTK one? Is one better than the other?
Presumably the sensors have different response curves to oxygen concentrations. This means that the voltages vary coming from the sensors for a given concentration, but the wideband controllers are designed for the sensor they work with to pull a linear voltage response to the a/f ratio.
The Bosch is cheaper...that makes it better from custom tuning standpoint.
________
Cheap glass pipes
leroy
Don,
Call them and see if they can supply a voltage out v. air/fuel ratio. Once you have that, the lookup table can be modified to match. Let me know if you need help changing the patch.
Jim
Trevor
I've got the PLX devices wideband with the NTK sensor in my Stealth. It's a few months old...bought it before they came out with the cheaper Bosch unit. Works like a champ. The only complaint I have is the free air adjustment wasn't quite able to trim out at my altitude (3,075'). Not enough adjustment. I would definitely buy it again though. I may get a Bosch unit for the Ty sooner or later.
Tommyquest
The Member's Member
About $150 I have Tech Edge version 1.6 which uses the $185 L1H1 NTK sensor. A buddy of mine just bought version 2.0 which now uses the Bosch at $30. I should have waited :x www.wbo2.com
canadian
sy in progress
Asked plx about a group purchase and here's the info:
Thank you for taking interest in our wideband oxygen sensor controllers.
You have a very nice website. We can give you a 10% discount on the
M-300 for a group purchase of 10 or more.
Our controllers are fully digital and can be programmed with whatever
voltage relationship you want. Currently it is set linear and follows
the following relationship.
http://www.plxdevices.com/M-Series-Controllers/WidebandOutputGraph.jpg
We can reprogram the output curve to match the DIY or any other curve
you wish on any of the M-Series controllers. Thanks please let us know
what you would like to do.
Support
PLX Devices Inc.
www.plxdevices.com
Ian Turgeon
Cascading Inspiration
nice :D
So what would be better, to adjust the code on the chip, or on the wb box?
oh, and just to voice this outloud, heres how I see this thing working.
Pull out your narrowband o2, screw in the wb, wire it up to the box, and wire the outputs to the ecm, using both the nb and wb output to feed the ecm. Now you can data log, watch the display, and run the ecm off one sensor?
sy112
alright, WB for dummies time.........
I really want to get into this group purchase. i am confused on the output stuff though. so basically I would like someone to explain (in detail) how all this works, maybe even word it to where this might be vault worthy. cause i believe that there are a lot of us who get the overall idea of WB and how it benefits us but we don't know the particulars of how to get it working right.
sytyguy
Moderated User
Count me in on the M300 (Controller, Display, & Bosch Sensor) if a GP gets kicked up.
Might be in for a couple.
canadian
sy in progress
Anybody want to volunteer to be the ring leader on a GP? I would volunteer myself, but with the house move coming up in the next couple weeks I won't have the tmie to dedicate to it. Any volunteers?
leroy
The diy-wb output goes to pin F14 on your ecm. The output is 0-5volts (similar to other ecm inputs). Make sure you have Dig's wideband code patch, and you are ready to go.
The code compares the f14 voltage to a lookup table to display the actual air/fuel ratio in your target air/fuel ratio field on the scantool.
HTH,
Jim
