Ecm 0411?
IGottaSy
Is anybody using this ECM? I think it would work awesome but don't know much about it. This ECM can be tuned using some free software too.
skwayb
NWSTP
Re: Ecm 0411?
From what I read on Thirdgen, TunerPro RT should be able to tune the ECM. Might have to make your own XDF for it. There is also a plugin you need to download so Tunerpro can connect to the ALDL. But it sounds like you will need to make the ADX yourself for the ALDL to connect. Still researching it but that is what I found so far.
hrodgmc
Re: Ecm 0411?
I've got a xdf for the 411. I 4get the OS. You will have to use the Roadrunner or pull the flash.
Re: Ecm 0411?
I woul dimagine this would be go for tuning later Vortec's. i wouldn't convert a SyTy to run 0411 woith code $59 available for our trucks.
