ashman
I’m currently using the Ram Charger setup with ‘in cab’ switches to engage HI/LO speeds and would like to use the ECM to control the cooling. $58/59 only have one output, so HI/LO control is probably out without some type of external controller.
My truck runs really cold in the winter, rarely getting above 150F with zero fan assistance (only road speed wind) and in the summer it runs around 170F using only LO speed. I’ve changed thermostats from 160F to 180F with no differences in winter temps.
Most of the fan controls are pretty straight forward but I need help with the following:
---== Electric Fan/Intercooler Pump ==---
Hot Fan Enable TEMP Threshold (Lower) (KFANCTHL)
Hot Fan Enable TEMP Threshold (Higher) (KFANCTHH)
Cold Fan Enable Coolant TEMP Threshold (Low) (KFANCTCL)
Cold Fan Enable Coolant TEMP Threshold (High) (KFANCTCH)
Cold Fan Enable MAT TEMP Threshold (Low) (KFANMTCL)
Cold Fan Enable MAT TEMP Threshold (High) (KFANMTCH)
1ST Time Decay Rate - Fan Anticipated Recovery (KFANCLC1)
Decay Rate Fan Anticipated Recovery (NOT 1ST) (KFANCLC2)
MAP Threshold For Incrementing Fan Timer (KMAPINC)
MAP Threshold For Decrementing Fan Timer (KMAPDEC)
Can someone put these in laymen terms?
thanks
thanks
