Ecm Pin Map
93 TY 2185
Re: Ecm Pin Map
psmvchaser said:
I need an ecm pin map preferrably with color and purpose of wires.
I have searched, but all links are dead.
Re: Ecm Pin Map
James Thomas said:
Are the Sy, 92' and 93' Ty's all the same?
Thanks!
James Thomas
The sy has a bed in the back, ty's have a back seat and a bit shorter wheel base.
Sorry, it is early and I am sarcastic at times.
VermontTy
Support Our Troops
Re: Ecm Pin Map
Attaboy Wade...way to come through in my absence. :tup:
If you need anything else, lemme know. I have a couple extra pics and what not of the ECM plugs.
EDIT
fukit....here they are. The ECM plugs color coded for wires. If you want to know what they all do, let me know and I can quickly label them up. This at least helps for a quick representation of what the plug looks like. The EF plug shows where you would put a wideband 02 input......
James Thomas
"NO CLASS"
Re: Ecm Pin Map
Hmmmm...... that explaines why the guy at the body shop said there was no place too mount the polished stainless cargo tie downs I got off of E-bay for my Ty :rotf:.
James Thomas
skwayb
NWSTP
Re: Ecm Pin Map
VermontTy you mind if I steel those pictures and put them on nwstp.com?
For the ECM they are the same..... now there are other areas in the 93 and the 92 Typhoon that are different from each other... i.e. Keyless Remote Entry Wiring is not even close to the same. The 92 Module has 2 connectors on it. The 93 has only 1.
VermontTy
Support Our Troops
Re: Ecm Pin Map
Not at all...in my NASTE gallery, I have one big album filled with every piece of documentation I come across, and make (like these). Link below...you're welcome to snag whatever you like.
http://www.northeastsyty.com/gallery/view_album.php?set_albumName=album442
