ECM Problems
typhoon92
My typhoon has been sitting in the garage for about 3 months.So today i decieded to turn it on and take it out for a drive.After charging the battery it started right up! But the bad thing was it was idling at 2 grand and it would not idle back down to normal RPM.First thing that came to mind was vac leak or bad IAC. I changed out IAC with the spare one i had and still had the high idle rpm.I ended changing out the ecm and putting in my ecm from my syclone.Problem was solved after changing ecm but what would cause the ecm to go bad? It ran great before parking 3 months ago.What went bad on the ecm to cause it to idle at 2grand? Could it be fixed?
Any help would greatly be appreciated!!
typhoon92
Re: ECM Problems
SY2455 said:
I would check all grounds. Were any codes present?
I did see the check engine light flickering off and on the whole time. Did not spend the time to get any codes. Is there anyone here that could take a look at my ecm? Nolan maybe?
