ecm removal
imported_ty1724
remove the lower dash pannel (the plastic cover under the pass side of dash)
unscrew one bolt atached two ecm bracet the gold one pull out and un plug
Phoon30
When you're putting it back in, remove the pass. side speaker from the dash and look down through the hole where it was. This makes it easier to guide the ECM back into place. Also, watch out for a vacuum line that's in the dash board near the top.
sy2206
Or relocate it so you always have access to it, then you don't have to keep putting it up and pulling back out every time you need to change something. 8)
ZMann
vertically challenged
If you will be playing with the chip frequently there is a way you can mount it so that half ur ecm is showing below the dash, and installing/removing your chip/memcal is a 20 second task. Im sure a pic would explain it all. Sorry, no digital cam. here. :cry:
