ECM wiring and cleanup
fivetodrive
CRISPY
I am looking at a Vault Post so I cannot reply to it so I am making a new post...
Since I am working slowly on crispy I was going back over my posts on things to do. One was to do the ECM wiring mod to help with the injector saturation and split the load. In this post it shows to just move the pin from c12 to c10...
http://www.syty.net/forums/showthread.php?t=57813
I know that Bill Shaw here is using the Sunbird injector wiring setup and he added the stronger drivers.
He states "The 749 has 3 injector outputs, 2 on one injector driver and one on the second injector driver. I've taken an unused pin (C10) and used it as a second injector output for the second injector driver to reduce the amount of current passed through the connector pin. "
http://p-928.home.comcast.net/~p-928/749mods.html
Is the difference just the sunbird wiring??? I know I am missing something here.. Probably peak and hold...
TrendSetter
Organ donor in training
Re: ECM wiring and cleanup
3 injector outputs refers to three pins on the ecm connectors (pin c10, c11, c12)
2 actual drivers exist inside the ecm.
-one driver is split off to pins c11 and c12.
-one driver is connected only to pin c10
The unused pin is actually c14. he tied c14 into c10, similar to how the stock configuration joins c10 and c11.
As far as i can tell, in order for that jumper to even matter, you need to add a pin to the connector in position c14 and join that to the wire coming out of c10. His intention is to reduce the current passing through a single connector pin.
Does the mod the the SyTY ECM actually work? Meaning has anyone ever noticed any difference?
TrendSetter
What do you mean? Lowering the load on the driver just makes it run cooler so it theoretically lasts longer. with high-z injectors, there may not be any seat of the pants advantage, it is more of an engineering 'feel good' if these ecms arent prone to burned injector drivers. if you make the move to low z injectors, I would imagine this mod is necessary.
V8 Sonoma GT
Mile High SyTy
who is this guy?
berzerker
wookie
who is this guy?
he is right .. the mod makes the difference in running peak and hold . it does help when running low z injectors . i have done the mods for my low z 55lbs injectors . with the options in injectors now the need to do this is old news . our ecms never really had issues , just needed modding to run bigger low ohm units .
TrendSetter
who is this guy?
Im supposed to by getting my first typhoon later today, so ive been reading up. I used to be big into modding the dsm ecm firmware a few years ago, which uses the same 68hc11 chips so I have been digging through code lately and the hardware information available for the 749s is amazing. physical computing has been a hobby of mine for a few years now.
fivetodrive
CRISPY
I'm glad to have someone on the board to 're look at some of this stuff. I welcome anyone with this knowledge!
