ECM wiring
jjorgensen52
NHSTE - I'm the only one!
My brother sent me this email concerning the wiring on his ECM harness (changing to a standalone) and I can't help since I haven't got that wiring either (with the motor).
Nearest I can figure the wires in question are neutral safety and MAP sensor
Any ideas?
>I am trying to find some information about the DRAC (the little white
>electronics box attached to the ECM) on the Typhoon which I cannot find
>in my diagrams or on Syty.net. All the diagrams I have seen show the
>DRAC as having 6 wires connected on the 9 pin connector and don't even
>mention the 4 pin connector. My DRAC has the 6 listed wires on the 9
>pin connector:
>7 = lt grn/blk = vehicle speed sensor
>8 = blk = ground
>9 = pnk/wht = ign switched power
>11 = brn = output to ECM speed input
>12 = ppl/wht = vehicle speed sensor
>15 = lt blu/blk = output to speedometer drive
>But I also have two extra wires, 1 on the 9 pin connector (10 = drk
>green = ?) and 1 on the 4 pin connector (1 = yellow = ?) which I would
>like to know what they do?
VermontTy
Support Our Troops
Re: ECM wiring
I'll be plowing through wires in the garage this weekend; I'll trace down at least the yellow wire on the single plug as best I can. As for #10...I haven't been able to find any documentation that shows it exists. This stuff is in your Ty, right?
jjorgensen52
Re: ECM wiring
Nope, brother's Ty ... we're special like that, have a pair of Black 93 Ty's :tup: ... thanks in advance man
SeattleSy#1255
Category 5 Conservative
Re: ECM wiring
Not sure if this would help....from sytyauthority!
VermontTy
Support Our Troops
Re: ECM wiring
The yellow standalone wire runs to the cruise control unit; my best guess is it backfeeds the speed of the car to the cruise control unit to let the cruise know if it needs to engage more throttle to keep speed up, or back the throttle off for coasting down a hill.
Pin 10 dark green I'm going to say is a ghost pin. I looked on 2 SyTy harnesses I have, and 3 K1500 harnesses I cut up, and neither has that pin 10 on the DRAC. All of them have 6 wires.
