turbodog
Hi, not sure if this belongs here or in Chassis electrical....
Was running fine. Pulled out of a parking spot, put it in gear, went maybe 10 feet and it died. Guage shows I have fuel pressure. ECMB (10A) fuse is blown. Pull my ELC (20A) fuse and stick it in the ECMB slot, it starts but stumbles bad and dies. Start again, same result. 3rd try, no start. the 20A fuse is blown. No recent work, has a Walbro with ~50k mi.
Pulled the wiring diagram up, looks like the circuits on that fuse are:
ECM
Oil Pressure Switch
Fuel Pump Relay
Antilock Brakes (deleted)
Am I missing anything?
Only other possibly relevant info... I have an oil leak, looks like rear main seal... but could be from oil pressure switch, down back of block. Is the switch back by the distributor, or is it on the driver side of the block, above the oil filter adapter?
Headin' out now to troubleshoot.... will check back in for any helpful hints.
Thanks.
ECM
Oil Pressure Switch
Fuel Pump Relay
Thanks.
