ECU removal
stariy
Can someone point to ECU removal instructions? I am sure they has being posted numerous time.
Thanks in advance.
:wink:
Sy-1177
Turbo Inside
Its up under the dash above the pasengers feet. Take down the black cover and there will be 1 screw that is holding up a metal triangle shaped bracket. Take that screw out and the computer will pull down.
TYPHOOL7
Post Hawk
no there are six screws toi remove the cover to the underneath part where the ecm is, after they aare out the ecm practically falls out...no there is a screw holding it in...i didnt put mine back in, unneeded.
no tricks just screws!HTH
Ian Turgeon
Cascading Inspiration
may have to wiggle it to get it out. putting it back in, some people have problems, and remove the speaker/speaker grill on that side to aid in visually lining it back up.
i just fiddle with it till it goes in correctly.. never had any major difficulties.
Falco
Dmi,
From offhand:
1. Disconnect negative battery terminal
2. Remove the passenger side kick panel (4 screws)
3. Remove the little lamp under the dash on the passenger side
4. The ECM is hold by one hex head screw, unscrew it and you can drop your ECM. It could be tight, but it should come out
To put it back I usualy remove the speaker grill and the speaker. This way you can help to manouver it into the right place from above.
HTH,
typhoonzz
Got Boost?
unless you get lots of messy passengers, you can just leave in on the floor :)
Not that it looks pretty, but it is a lot easier if you make constant chip changes...
Mine has been on the floor for over a year and no major issues yet
