eDist wiring harness.
canadian
sy in progress
Other than FAST, does anybody have a source on an LS1 coil wiring harness? I've talked to their tech support and they say the only difference between the two eDist part numbers that they list is the wiring harness, and that the universal box will run LS1 coils.
I picked up a universal box on eBay, but need the LS1 wiring harness. I can get it from them for about $100.00. Just wondering if there is a SyTy vendor that sells it.
Try Me
Re: eDist wiring harness.
when you say "universal box" do you mean a FAST universal edist box? Which harness do you need, the one that goes out to the coils and comes up to one plug, or the one that goes between the two banks and the edist box?
canadian
sy in progress
http://www.fuelairspark.com/Products/Information/ElectronicDistributors.asp
I have P/N [font=Arial, Helvetica, sans-serif]305000. Talking with FAST today, I asked if the only difference between the two boxes was the wiring harness and he confirmed that was the case. Notice how the LS1 part number is described as "[/font][font=Arial, Helvetica, sans-serif]LS1 “coil-on-plug” Direct Fit Part". What I need is everything that comes with 3050001 except the box itself.
My assumption was that the harness shown at
http://www.fuelairspark.com/Base/Images/Products/HiRes/ElectronicDistributor.jpg
is the part that differs between the boxes.
[/font]
skwayb
NWSTP
Actually they don't provide a harness.. They provide the connectors, the wires and the wire diagram. You have to put the wiring together. They don't know if you are running 4, 6 or 8 cylinders. So they just give you the parts unassembled and you have to put it together yourself.
canadian
sy in progress
I'll have to take pictures of what I have. Anybody have pictures of the parts for the LS1 eDist?
skwayb
NWSTP
If you go here I have a whole bunch of pictures the LS1 e-Dist.
http://www.nwstp.com/forum/photo_album_view.asp?cname=eDist&mid=18&cid=19
This is probably what you are really looking for.
jjorgensen52
NHSTE - I'm the only one!
I have a set of the plugs that you need to connect the eDist to the LS1 coil subharness (the one that connects the 4 packs to one plug)
canadian
sy in progress
Exactly what I was looking for. I basically need everything that's in the ziploc bag. I may just drop the coin and get it from FAST so I know I have everything. No vendors have mentioned that they sell it.
skwayb said:
