EEPROM/chipping questions
InvisiBill
I'm moving closer to actually messing with chipping, and just wanted to verify a few things...
  • The Atmel 27C128 is a stock replacement UV-erasable EPROM.
  • The 29C256 is an EEPROM double the capacity of the stock chip.
  • The ~$150 Pocket Programmer is now supported under all versions of Windows, and actually works (unlike some companies' "support"), and will burn stock chips without any adapters.
  • The Romutator also works in our stock setup.
A lot of the Chitown chipping stuff seems to be non-SyTy-specific stuff copied from other places, so I just wanted to make sure I'm not thinking the wrong thing before I start buying stuff...
Also, does anyone know of a premade MEMCAL-EPROM pin adapter thingy, for burning chips without taking them out of the MEMCAL?
leroy
Try a CHC60G-ND from Digi-Key. Cut header and spread pins to fit zif socket. Makes two.
Jim
InvisiBill
I am nowhere near ready to do "real" tuning stuff yet. I mostly just want to mess with the on/off and temperature kinds of things. Like EGR, first run boost limit, IC pump turn-on, etc. I got an ATR Pitbull really cheap, so I was just going to replace the EPROM with an EEPROM. Then I wouldn't have to worry about UV-erasing and adapters and not fitting in the housing and all that stuff. It would also allow me to tweak others' (there are a few guys around here that said they'd be interested in that stuff too) MEMCAL's programming without all the hassle since I do have access to an eraser.
At this point I just think it would be more convenient to have a "stock" MEMCAL setup where I can burn stuff without having to mess with adapters and sockets and PROM-swapping.
