efan wiring
Flyin Ryan
hated cuz he drives fords
Going to be relocating my battery to the bed again sometime next week and would like to finally put my volvo efan in and well would like to do it at the same time so my question is with the battery being moved to the bed would I still want to run a power lead directly from the efan to the battery? or can I just say run power to the efan from the distrubution block on the firewall? I will already be running a lead from the alt to the distrubtion block so would that be too much to the dis block? is that even possible?
Sorry for the stupid questions but I don't know much about wiring
also.. I have a relay and fuse holder for this project.. where would these get wired into this equation?
Thanks for the help
live1053rulz
Nor Cal SyTy
Re: efan wiring
You can wire up a power from the alternator or firewall, run a ground, and get the on signal from the green wire for the intercoolers water pump that comes out near your windshield washer resivoir. It's one of three wires I believe. I just used that and a Bosch relay.
2kwik4u
Resident slow guy
Re: efan wiring
I had been wondering which wire controlled that relay.
The green wire is a switched ground right?
Flyin Ryan
Re: efan wiring
I always thought it was
orange-pump positive
black-pump negative
green-low coolant
George Blake
DONATING MEMBER
Re: efan wiring
The low coolant light doesn't do anything as it's not hooked into anything. It did plug into the CCHE but the "light" on the gauges doesn't respond to it.
Flyin Ryan
Re: efan wiring
Which would mean for "switch'd on power" you would want to tap into the orange wire not the green correct?
George Blake
DONATING MEMBER
Re: efan wiring
Let me go out and look at mine. What I did was hooked mine up this way:
I took the CAC pump relay that is controlled by the ecm and made it so that it activates a 75amp relay that supplies power to my fans (ramcharger type setup). Then, I grounded the cac relay so that it activates the fan with the ignition until I can get around to reprogramming the chip. I have a 93 ty so the colors should be the same. I'll find out what they were for sure though.
Are you trying to do this or are you just wanting to know which wire activates the A/C? It seems like a couple different routes are getting mixed up here. A/C relay activation is used by some aftermarket controllers to override the temp probe and turn on the fans whenever the A/C is turned on.
Flyin Ryan
Re: efan wiring
That sounds exactly how im doing mine currently.. Im using a 40 amp relay grounded, power lead to fan from relay, power lead with 35 amp fuse from relay to distribution block then the last lead to either the ign on the fuse block or the ic pump power lead(which would be alot better) so yea if you could let me know that would same me a bunch of time and i'd appreciate it.
