Efficientcy ?
G
Guest
Guest
How much more is a ,let's say a mike Lee Air to Air set up versus a ATR IC .with Jabsco ,and stock lower .Big ,medium or little difference over this ATR and jabsco and stock lower set up
Tooky
Serious about performance
I don't know about Mike Lees but I have 1 first hand experience with Air to Air intercooler I feel the need to post. A friend of mine had a 20G with converter on stock motor and switched from stock IC with ATR aux and pump, to a huge air to air and did not go 1 tenth faster!! The only difference is when he lets off the gas in boost it sounds like a Buick Grand National now. It was the biggest waste of $. That is my opinion and maybe air to air will give you 5 tenths, I cannot say. I will be sticking with stock intercooler until Mid 11s after that point near the 600 HP range I guess I might see some "real" ET gains if I switched to an air to air. So maybe it depends on the HP you are making and/or what turbo you are running now? What do you have?
sy112
a2a gives you better recover time after a run, not so worried about heat soak, which is great if you run it very hard on the street or track.
Tooky, compare the et difference if you run 5 passes back to back and then the a2a back to back, then you will fully understand the difference.
the a2w system is kind of limiting as far as airflow goes also, won't really notice it on a mildly fast truck but you will on big horsepower numbers.
a2a are expensive and really only need to be on the big guys, unless you beat it real hard on the street and are worried about heatsoak. other than that a2w works fine, works even better if you do some mods like the cooler in the bed with ice and stuff, actually give you below ambient temps for the run, which is gooder. But still a little limiting on the airflow.
all this info is courtesy of the search button, I have neither the time nor money to put it to the test personally :-? :cry: but have been reading extensive cause I am looking at alternative methods myself.
