I had DM hooked up on a long run, about 100 miles or so. at first i noticed that the truck was bogging then it would pick up, and bog again.... So i watched DM for what was going wrong. I saw two things, the EGR would enable and my IAC temp would rise to around 140, then it would drop as the EGR turned off... im thinking ok strange... I bump the ult off t115 to t116 .... egr off, no problems....
on my way home i had my mom in the truck, i was showing her datamaster and had he holding it. I explained that i had used DM to figure about the problem above... i toggled it back to t115 to show her the EGR acting up... it didnt. i was like hmm thats odd.... then i notice that ive got a lot of boost pressure. The computer said i had about 5lbs to all the way up to 20lbs of boost... however neither of my boost guages showed anything (stock or aftermarket)... I was doing about 60mph this entire time, hardly touching the gas... so i SHOULD be in vaccum.. yet the computer was just throwing out the most random boost numbers... (but no EGR,, hmmmmmm)
i pull over, shut it off, start it back up... EGR kicks in, boost stays below 0.0 unless i get on it... everythings fine ... except for the fact that the EGR keeps blowing a lot of hot air into my intake and bogging my truck down... so im now running around on t116... i used to run around on t115 w/o any probs....
whadaya guys think?
whadaya guys think?
