EGR Block off plate?'s
Hu Ryde
Do I need to reroute the vaccume lines or just plug?Will I throw a code with the block off plate?
Tooky
Serious about performance
With the stock chip I know it throws a code (not that I thought it was such a big deal..) But with the Ultimate it should not matter in any version other than T1-15 and even in that one it still may not throw the code but I don't have an Ultimate so if you want to verify what I said, someone will have to respond with firsthand experience.
As for the EGR vacuum line, I just plugged mine and it seems to be working swell with no ill effects but I also am curious what everyone else does. I know my friend Adam just leaves his completely open creating a big whistling vacuum leak but his truck runs like stink with no problems to boot!! (Maybe that is his secret? HaHaHa)
Hu Ryde
I do have the Ultimat Chip so hopefully it won't throw a code since it disables the EGR anyway. As for the vaccume line I think I'm going to plug it like you said. Thanks bud!
Mephisto
These trucks are cursed
whats the function of the egr anyway? cant be all that important, if you can rip it out and nothin happens.
warmpancakes
defiled the egr serves two purposes one is cleaner emissions, and the other it is supposed to lower knock by introducing a inert gas into the combustion chamber Ken
Hu Ryde
So if I remove my EGR will I have more knock at WOT? Remember, I have the Ultimate Chip so it is disabled. Does it only disable part of the EGR, or is that even possible? How does inert gass reduce knock?
Daron
The stock chip will test for EGR operation only under part throttle cruise operation. Mine would sometimes take a week or two to pop a code.
Inert gas doesn't have any oxygen in it so, it will not contribute to the combustion event. Therefore the burn will not be as "hot", thus slowing the flame front. Detonation can be described as the premature explosion of the fuel mixture. EGR aids in preventing detonation by taking up space in the combustion chamber with a useless gas, where there could be some burnable oxygen. The more you fill the combustion chamber with useless gas, the less the mixture will be apt to ignite. Therefore, the conditions that trigger a knock event will be less likely to be present. EGR operation is not an issue at WOT, unless you consider the effect "heat soak" may have on the intake and combustion chamber, since the chip doesnt enable the egr at wot.
Since I was still getting my truck E-Checked at the time I disabled my EGR, I just removed my EGR and filled it's passages with JB Weld, making my own "block off". I then bolted the EGR back on and hooked the lines back up, so it looked functional.
Since you have the Ultimate, and the EGR function is disabled, removing it is really a matter of visual preference.
_________________
Daron
1992 Typhoon Blue/Gray
1991 Syclone Best 1/4 12.42 @ 106.1
Member Of Freakin' Ohio (MOFO) SyTy
<font size=-1>[ This Message was edited by: Daron on 2001-11-30 14:43 ]</font>
SyTyJedi
Jedi Council
I would go ahead and pull the EGR hardware out if you are not using it. Makes it easier to get into that area from the top and since space is at a premium underhood anyway, it can clean up some lines, elec and a silly looking hunk of metal hanging off the intake.
Just IMO...
Tyler
