EGR question
syty9933
if i have a pitbull chip will it have an egr problem if i block it off. And if it dosent who is the one who sells them?
Re: EGR question
The ATR pitbull disables the EGR in the ECM. The only thing you gain by removing the EGR valve at the upper intake manifold is space. The passage for heat still reach EGR with a block off unless you block off the cylinder header passage or plug the low intake passages.
