EGR Stress
syclomatic
Syclone #2481
Ok, Is taking the Egr valve off really that important power wise. I got my truck and it already had a block off plate, but it was y and thin. I burned up 2 gaskets cause it was leaking, don't know how it is leaking still but it is! I tried making a pl8, and that didnt work. Should I just go buy a new EGR valve? Or does anyone have a pl8?
ty166
Re: EGR Stress
look here ,
http://www.syty.net/forums/showthread.php?t=43699&highlight=egr+block
hey i think im gettin the hang of this forum / search thing...... now if i could only figure out the little faces ......lol
SBNova
Re: EGR Stress
Power wise, its probably a good idea to have it deleted, or just turn it off on the prom. After installing my new IC pump I knew I should have colder intake air temps, but I didnt confirm them by datalogging. Then later in a quest for more mileage, I turned the EGR back on (using it to add timing and cut fuel at cruise). After I datalogged with the EGR on, I couldnt believe my eyes!! I had IAT's nearing 200 degrees F at cruise!!! If I accelerated the temps would drop but not fast enough for my liking. I turned the EGR back off and in two to three minutes my IAT's were 97 degrees F. WOW!!
Not only does hot air make less HP than cold air, but the ECM will reduce timing as the air temps climb in an effort to reduce detonation (safer that way), which will further reduce HP.
Vertigo
Addicted to Turbo AWD
Re: EGR Stress
So you were able to verify an *increase* in fuel consumption with EGR ON vs EGR OFF? I know that, in theory, the EGR is supposed to give you better cruising mileage even taking into account the increased temps (I believe the higher temps are _after_ the IAT sensor so the ECM shouldn't pull timing).
I'm curious because I'm currently debating whether I should scrap the EGR on my wife's Ty used mainly for highway.
gmcturbo
Re: EGR Stress
egr is simply a device for reducing NOX emissions,its also supposed to REDUCE detonation actually by reducing combuistion temps in the cylinder
the IAT sensor DOES see the heat that is VERY obvious
sy2675
He Saved the Pimp'n Game!
Re: EGR Stress
OR click on the Go Advanced button and they magically appear as well! :rotf: :tup:
Flyin Ryan
hated cuz he drives fords
Re: EGR Stress
I deleted mine because within a single minute it would raise my temps 40 degree higher or more.. which I wasn't happy with so that shit got yanked!
SBNova
Re: EGR Stress
Mileage should theoretically increase with the EGR on, or active If I remember the stock tune correctly. There is an injector pulse width change and a timing change that is programmable in the ECM when the EGR is active.
Vertigo
Re: EGR Stress
This was my understanding. The EGR takes the place of intake air with higher oxygen contents thus requiring less fuel and enabling a leaner burn...again *in theory* :)
