Electric cooling fan size?
heavy breather
FBI enforcer
I am about to install one of the ARA A2A kits and need to put in some electric fans. What sizes will fit? What is the minimum cfm for our trucks?
syclonekid43
i didnt get a chance to put fans on the sy yet. but on my 88 s-10 blazer i put two 12" fans on it. they fit like a glove. from what someone told me when you put dual fans on. put one in front of the radiator right behind thr grill. but the other one behind the radiator on the opposite side(one on the right one on the left). and you reverse the rotation on one of them. one is going to pull. the other is going to push. how true i dont know i had them this way on my blazer and also both in front of the radiator and i didnt see a diffrence. anybody else hear about doing it this way. :drinking: :drinking: :drinking: :x-mas:
E-Rue
im using the flexalite S10 fan/housing. its controlled by the intercooler turn on from a 50lb chip, so i dint have to use that bullshit probe in the radiator. works great.
e
smeagol
http://www.chitownsyty.com/bg/pics/syfans/
That's my setup, got it from Ramchargers, they sell it as a universal setup, as well as in kit form for Buicks. I got the universal setup, as it's cheaper, doesn't include relays. I think it's around $80. I had to modify the plastic shroud a bit to fit, nothing a dremel or air tool can't fix.
My truck runs too cold now, actually. I have the fans set to kick on at 168° F via chip control, and it will barely warm up to that temperature. The fans kick on, then go right back off.
canadian
sy in progress
How did you hook everything up without the relays and such? Just buy a relay and have it triggered from the ECM?
smeagol
Yep, I got a couple of basic relays that were triggered from the IC pump relay.
The ramchargers setup is configured for 2 fan speeds, which our configuration doesn't support, but would be nice. I may go to such a setup in the future, we'll see.
