Electric Fan COntrol??? HELP
Well, there is a lot of information about tuning but I couldn't find anything on Fan Control, just that it is possible. I could use a crash course in this area, or for now a simple answer will do.
I got my fan all rewired with the proper relay/wire gauge etc. and now I need to know how to control it with TunerPro. I can't get it to shut off.
My set-up is this: I have the IC pump wires to trigger the relay that runs the fan. I also have a switch wired up in the cab that grounds the IC relay so I can turn the fan on manually as needed. It is currently in the off position.
My question is that I can't find the fan/IC control in TunerPro. I did find a dozen or so related charts all in one section but they don't seem to control the fan (in my case the IC relay). Right now it starts up 1-2 seconds after the engine starts and doesn't turn off until the key is off. If I turn the key on, I can control the fan with the switch. If I start the engine then the fan runs all the time.
I'm sure it's temperature related but I've raised the temp settings on what I thought would control it but it keeps on running. I was doing this while emulating. Am I missing something here?
I'm sure a few of you are using a similar set-up so What are adjustments are you making in the TunerPro BIN?
I'd like to have my fan come on around 190 and back off maybe 170... not really sure about this yet, I'll have to experiment with what works. Whenever I need it I can turn it on via the switch for times like at the track when i want it as cool as possible. I'd also like to keep it running for 15-20 seconds after turning off the engine.
Thanks in advance for your feedback, I'd like to have it done before Homecoming.
