Re: Electrical problem only while truck is running
Ok, update this morning. Fixing both of the grounds above solved the voltage issue that I was seeing on the MAP sensor output. It is the same whether key on or running (or with a very small margin). All of my firewall and engine grounds are ohming to near zero and all are consistent. Can someone tell me where the factory frame ground should be? I'd like to check the condition of that while I'm at it.
But... This didn't really fix the weird issue with MAP output above 16in vacuum. The voltage is right now, almost spot on with the tables that I've found and given my altitude, but the truck still dies off if I give the MAP more than 16in vacuum (and at idle the truck makes 17inches). I will say though that the problem is less pronounced in the short drive and idling that I did last night. Fixing the grounds certainly didn't hurt anything.
I would love to pick the tuner's brain (ATR) but as I understand that ship has sailed. I'm fairly familiar with similar era OBD1 systems but can't think of anything that would cause this and don't really want to randomly throw parts at it.
Here is a quick recap of the MAP issue. Using a vacuum / pressure pump to manually control vacuum to the MAP... I can pump in 15inches of vacuum and the truck idles beautifully and rock steady, as I cross 16inches and if I hold at 16 or more the truck will choke and die within 5 seconds. At idle, the truck tries to make 17inches but is constantly struggling against this apparent system problem.
All of the above ground troubleshooting was because I thought that problem was causing a sensor range / resolution problem with the MAP, but now it reads correct voltage but the problem above 16inches of vacuum persists.
Cleared codes and no codes present outside of ABS. Tuneup parts were changed last summer (plugs, cap/rotor, fuel filter) and like I said, at 15in vacuum it really idles great. Next step will be to get datamaster on it I guess, need to round up an obd1 cable for it. I bet that the problem becomes pretty evident if I'm logging a data stream.
