tbauer03
TRBOBOX
A couple weeks ago I went to start my white Ty, turned the key and all power just shut off off when it was about to bump the motor. I checked all the electrical connections on the battery and when I did the power came back on so I figured it was bad terminal connection I snugged them up then tried again and it shorted out again. cut all power. Repeated the process a few times before I called AAA. I was in a Wendy's parking lot. Anyway the AAA guy ran some test on the battery and deemed it good, then he went through the same steps I did with the same result. He concluded it was shorting in the starter and towed it home. Truck has set in my garage until today I realized i had a lifetime warranty on the starter and I took it into advance auto and they just swapped it out. I got it installed and put new terminals on the battery and it is still shorting out when i bump the ignition.
I am guessing the ignition, battery cables, or a fuse is the next culprit but how to I troubleshoot this so that i am not just switching out parts.
Thanks,
Ted
Thanks,
Ted
