INNOVATIVE MSBC ELECTRONIC BOOST CONTROLLER $425 shipped
includes the instruction manual
going on ebay soon
also including some various vacuum lines and fittings
what it can do:
The MSBC-1 has the following features:
• Six stage programmable boost control.
• Useful for street, dirt or drag race applications.
• 0-60 PSI target boost range for each stage (1 PSI increments).
• Up to 9 different Ramp settings to control how fast boost is allowed to build.
• Launch stage for drag racing.
• Shift input for automatic stage selection for drag racing.
• Front panel stage selection by driver for road or dirt use.
• Readout of actual boost during boost control.
• Two analog data recorder outputs – Actual boost level, Target boost level.
• Two solenoid drive outputs – One Increase boost output, one Decrease boost
output.
• Can be used with Single or Dual port waste gates.
• Uses electronic pressure sensor in manifold to monitor and control boost.
• Will force waste gate to produce preset target boost level even with air density,
load, or mechanical variations.
• Can be used with manifold pressure only or external pressure source for control
I also have a brand new never used Exile Turbo electronic boost controller. It's basically the same exact controller with a few extra add ons.
$550 shipped
It's on ebay right now but will end the auction if it sells here
retail is $700
what it can do:
• 0-80 PSI target boost range for each stage (1 PSI increments).
• Up to 18 different Ramp settings to control how fast boost is allowed to build.
• 4 built-in timers for timed boost control.
• Built-In self test feature.
output.
• Can be used with manifold pressure only or external pressure source for control.
going on ebay soon
what it can do:
output.
$550 shipped
retail is $700
what it can do:
output.
