Emission comparison
jusssi
How are emission testing limits in california and other states where they check them? Here in finland '92 and later are low emission vehicles and year inspect includes emission test:
at idle: CO max 0.5% HC max 100ppm, at +2000rpm CO max 0.3% HC 100ppm and lambda 0.97---1.03
Thinking that do I have changes to pass with turbotweak chip :roll:
It's just a six
Super Member
Re: Emission comparison
California smog regs
Smog inspections are required unless your vehicle is:
• Hybrid
• Gasoline powered 1975 year model or older
• Diesel powered 1997 year model and older or with a Gross Vehicle Weight rating (GVWR) of more than 14,000 lbs
• Electric
• Natural gas powered with a GVWR rating of more than 14,000 lbs.
•Motorcycle
• Trailer
When you get your vehicle smog tested, just make sure your engine is reading 14.7 A/F or even a bit leaner.
I ran as lean as 15.0 A/F ratio. Just as long you do not have a lean miss.
Also, when you have your timing retarded, this will help burn more emissions
Ty#365
BOOST LAUNCH KING
Utah: CO 1.2 @ idle and 2500 rpm, HC 220 idle and 2500. Thats all we test for, easy shit.
gkrcr882
SyTyless......for now!
WI is just the OBDII system check, no tailpipe testing here anymore.
crariley
In Northern VA (around the DC area) we have to do the OBDII check and a visual inspection for cats every 2 years. I think VA residents not close to a metropolitan area do not have any smog test at all just an annual safety inspection.
