Engine acceleration studdor, very slow acceleration, need help
kashdog1
Ok my typhoon is having problems when it accelerates. When accelerating the engine tends to studdor, greatly reducing the acceleration. It also is getting full boost, but still is going much slower then it should be at full boost. Not sure what the problem is, maybe just a tune up would fix but not sure. Help is greatly needed, thanks.
berzerker
wookie
Re: Engine acceleration studdor, need help
is there a check engine light with this. if so check the vacumn lines , check map sensor wiring. and the ignition sytem. have you done any changes to any of the before mentioned lately . if so double check anything you might have changed . have you changed chipping ?
kashdog1
There is no check engine light on, I've replaced the vacumn lines fairly recently so they should be fine. Chip has not been changed.
