Engine and Tranny are being dumb
syty9933
I just finished: Painted Valve covers .Painted and polishing the upper intake, polishing the intercooler, intercooler line replacements, and a new intercooler hose , Adjusted the Throttle Body cable a lil, and took off the vacuum ball( i can put it back on if its a problem. While putting all this together the battery died.....so i got a new one today and stated it up. I let it warm up a while. and took it out. When i got on it and WOTed it it only had 10 psi max. instead of 15 and then it shifted at 3k Rpms :dunno:. and it woudnt shift in 1st sometimes while cruising unless i let off the throttle compltley? and on top of it all it shifted very rough. Any ideas guys?? Vacum Lines maybe?
syty9933
Re: Engine and Tranny are being dumb
how did you adjust the tv cable?
ithe cable with the button i pushed in, and moved the cable as far forward as i could, cause when i was wot on the pedal it wasnt all thw way turned one the throttle unless thats normal???
syty9933
btw, how do i know if my throttle cable is adjusted right?, because when i get somone to sit in the seat and floor it i can go under the hood and move the throttle open more. is it supposed to be like that?
SY2932
Administrator
Removing the vacuum ball won't cause problems unless you didn't plug the lines that you disconnected.
With regards to the TV cable is MUST be adjusted correctly or you WILL burn the transmission up. You can read about it here.
syty9933
I read another thread about a guy with the same exact problems as me, and with not shifting at ahigh rpm it probally dosen allow the turbo to put out full boost. This should solve it all .....thanks man, good thing i only took it around the neighborhood first. :D
