Re: engine block
unless youre going with a bowtie block or some other crazy aftermarket setup, stock blocks are generally all the same.
Go find a PRE-1995 4.3L without balance shaft and you should be fine. (Z vin engine code)
Also, anything PRE-1992 should be without a balance shaft (reguardless of Z or W vin engine code)
