silverblaz
ok i know this has been asked a million times before but as we lal know the search works as good as a ford ... any ways i dont know what the difference is between the syty block and a 4.3 block or a vortec block. i know the balance shaft but if you remove the balance shaft is there that much of a difference in the blocks??? what i am getting at is i am putting a syty engine in my blazer now i have everything but the short block so i need to build that next now i used to work at a machine shop so i am just gunna go ask my old boss for a block but i need to know what one i want do i want an older 4.3 blcok a newer balance shaft block ?? i am gunna do a 4 bolt main conversion on it but if you guys could give me some idea what way i should go that would be great thanks
