Engine Block
RMassa187
Does anybody know what, if any, modifications were done to the production Sy/Ty blocks? Are they stock 4.3 Vortec blocks?
jwaller
Evil Genius/SyTy Guru
Re: Engine Block
vortec blocks are different.
stock syclone blocks are the same as a 91 Z code TBI block. only change is the Nodular iron main caps for the syty blocks.
RMassa187
Re: Engine Block
So still just the 2 bolt cap in nodular iron? I have a 94 CPI engine. Will the intake bolt up or do the runners not mate up?
Mtn Z
Re: Engine Block
Yeah they are still 2 bolt. A 94 CPI motor should be L35s. If that is the case, they will bolt right up.
RMassa187
Re: Engine Block
So a stock Sy/Ty is still using the stock LB4 cam? What about the L35 heads Any mating probs with the Sy manifold?
SY2455
70's Veteran
Re: Engine Block
The Sy manifolds (intake and exhaust) will bolt right up.
