engine build questions
TurboJunk
questionable
after long hours of searching i didnt find what i was looking for ... i need to know desperately if stock syty push rods will work with vortec? and with intake manifold gaskets all i need to do is glue 2 stock vortec gaskets together ?
last but not least will roller rockers fit under stock vortec plastic valve covers?
0260IN3
Engine Builder
Re: engine build questions
The answers are as follows:
Mabey, NO, and NO
The stock pushrods may work but need to be checked. The intake gasket you need is a felpro 1203. The only roller rockers that will fit under the vortec plastic covers are the roller tip comp cams style rockers (not a full roller w/alum. body)
