ive been driving the typhoon the pass two days and today i had to pass someone so i got it up around 80mph. looked in the back and saw a cloud of smoke thought i went to close to the sholder and kicked up some dust. tried it again flooring it and when i let go of the gas smoke came out.
got home and a guy stoped to looked at the typhoon at the same time it was smoking from the wheel wells. shut the car down looked under and notice it was wet on the down pipe. were it connects to the cat. it looks like trans fluid from the seal on the pan. is there any thing in that area that could leak?and why is it spilling out on high speeds? also did a compression when i changed the plugs every cylinder is in 158-160psi. during the tune up notice oil was over filled alot. Is it possable that oil got into the pvc system and when i got on it its clearing out? or should i look some place else the truck has 40,000 miles on it thanks for the help guys
