Syborg Twin Turbo
Syborg Twin Turbo
Okay putting together a check - list of all of the parts to build a long block. (copied it from a gm site) See if i got everything. btw - when i did this it is for my aluminum bow-tie block
Qty Description
1 BLOCK, BARE
1 *PIN,DOWEL REAR TRANSMISSION 19.5MM
1 *PIN , DOWEL, HEAD 15MM SPLIT
5 *PLUG,FREEZE (34.3 MM)
2 *PLUG,WATER/JACKET DRAIN (1/4 - 18" NPT)
1 *PLUG,OIL GALLEY 1/4- 18" NPT)
1 *BEARING, CAM #1
2 *BEARING, CAM #3&4
1 *BEARING, CAM #2
4 *CAP, MAIN BEARING
8 *BOLT,MAIN CAP (11MM - 1.5 X 93MM)
2 STUD, ENGINE LIFT BRACKET(10MM - 1.25 X 15)
2 BEARING, MAIN # 1 & 4 STD
1 BEARING, MAIN #2 STD
1 BEARING, MAIN #3 STD
1 SEAL, REAR CRANK, OIL
1 COVER, ENGINE FRONT/W POINTER
1 GASKET, FRONT COVER
3 BOLT,FRONT COVER, (8MM - 1.25 X 70)
1 SEAL,FRONT CRANK,OIL
2 HEAD,COMPLETE WITH VALVES
2 *HEAD,BARE W/SEATS & GUIDES
6 *GUIDE, PLATE PUSHROD
3 *VALVE, INTAKE
3 *VALVE, EXHAUST
6 *SPRING, VALVE
3 *SHIELD, STEM OIL
6 *CAP, RETAINER
12 *KEY, VALVE SPRING RETAINER
6 *STUD, ROCKER ARM, (10MM - 1.5 X 18)
6 *SEAT, INTAKE & EXHAUST VALVE
2 *STUD, MANIFOLD, (8MM - 1.25 X 79)
6 *SEAL, O-RING
3 *SEAL, INTAKE VALVE STEM
2 GASKET, CYL HEAD
8 BOLT, HEAD (LONG) (11MM - 1.5 X 93)
8 BOLT, HEAD (SHORT) (11MM - 1.5 X 68)
12 ROCKER ARM KIT, WITH BALL & NUT
12 *NUT, ROCKER ARM (10MM - 1 )
1 COVER, VALVE ROCKER ARM (RH)
1 COVER, VALVE ROCKER ARM (LH)
12 REINFORCEMENT, ROCKER COVER
2 GASKET, ROCKER COVER
1 STUD , ROCKER COVER (6MM - 1 X 13)
1 NUT, ROCKER COVER (6MM - 1)
12 ROD PUSH
12 LIFTER, VALVE, FLAT
6 GUIDE, LIFTER PUSH ROD
1 CAMSHAFT
3 BOLT, CAM SPROCKET (8MM - 1.25 X 20)
1 CHAIN, TIMING
1 DAMPER, TIMING CHAIN
1 SPROCKET, CAMSHAFT
1 SPROCKET , CRANK
1 ROD, CONNECTING ASM W/BOLTS & NUTS
1 *BOLT, ROD (9MM - 1 X 55)
1 *NUT, ROD (9MM)
1 BEARING, ROD (STD)
1 PISTON W/PIN (STD)
1 RING, PISTON (STD)
1 CRANKSHAFT
1 *BUSHING, CRANKSHAFT PILOT
1 DAMPER, HARMONIC BALANCER
1 BOLT, DAMPER ( 12MM - 1.5 X 65)
1 KEY , DAMPER
1 WASHER, DAMPER
1 PAN, OIL
1 *PLUG, OIL PAN DRAIN (12MM - 1.75 X 26)
1 *SEAL, OIL PAN DRAIN PLUG
1 GASKET, OIL PAN
1 BOLT,OIL PAN (6MM - 1 X 20)
1 STUD, OIL PAN (6MM - 1 X 13)
1 NUT, OIL PAN (6MM - 1 )
1 PUMP, OIL
1 WATER PUMP
2 VALVE COVER GASKET
1 FRONT COVER GASKET
1 SEAL, CRANK FRONT
1 OIL PAN GASKET
1 INTAKE MANIFOLD GASKET KIT
1 REAR CRANK SEAL
1 THERMOSTAT HOUSING GASKET
1 OIL FILTER ADAPTER GASKET
1 O-RING ADAPTER BOLT
2 HEAD GASKET
Qty Description
1 BLOCK, BARE
1 *BEARING, CAM #1
1 *BEARING, CAM #2
3 *VALVE, INTAKE
3 *VALVE, EXHAUST
6 *SPRING, VALVE
3 *SHIELD, STEM OIL
6 *CAP, RETAINER
6 *SEAL, O-RING
2 GASKET, CYL HEAD
12 ROD PUSH
1 CAMSHAFT
1 CHAIN, TIMING
1 SPROCKET , CRANK
1 *NUT, ROD (9MM)
1 CRANKSHAFT
1 KEY , DAMPER
1 WASHER, DAMPER
1 PAN, OIL
1 GASKET, OIL PAN
1 PUMP, OIL
1 WATER PUMP
1 SEAL, CRANK FRONT
1 OIL PAN GASKET
1 REAR CRANK SEAL
2 HEAD GASKET
