Engine Control - ECM or Aftermarket ?
Lynn D. Brown
SyTy guru guys,
I am going 4 the 500-600 HP range w a Bowtie, Vortecs and a PTE-63. Am I getting out of the range of the stock ECM ? I will probably need at least 55 # injectors (suggestion ?), and then I would need to mod the ECM w Lo Imp drivers. That's what I have on my GN, and if I try to idle any lower than ~ 1000, it kills all the time. Does anyone even make a chip for this ?
Of course everyone wants to sell me a DFI w wideband for $2000.+, but can the stock ECM be made to work w the right injectors and Chip ? May still need to pass Smog also.
TheObiJuan
i wonder if the aem ems will work with our vehicles.
i know that the engine management system will work with all of the gm sensors.
Will_in_China
Truckless Wonder
I just called them a few weeks ago...
Their answer for GN's and SyTy's was "the Generic one".
That WOULD be totally sweet if they made one that works with GMECM/OBD1 stuff...
The cool thing they had was a direct-swap compatibility deal for select models.
Unplug harness, insert new brain.
If we got together with the Buick guys on volume, we might be able to convince them.
10secTy
Sy-Ty builder and Tuner
We modded Turbotonys ECM with the different drivers for the Low Impedance drivers. Tony is using 75's and they work great. The dirvabilty of the truck is awesome. Even better than my wifes with the 009's.
If you want E-mail me I can mod your ecm if you like.
Nolan Nykyforuk.
TurboV6@telusplanet.net
