Engine cut out...w/pop sound?>
Mkid
My new motor is cutting out when you snap the throttle. It cuts out and makes kind of a pop sound from the passenger side of the motor. Almost the same as a fuel cut off from passing the rev limiter[engine shuts down for a second} but with a light pop sound??
It hesatates and cuts out with a light pop noise and then regains itself. This problem occurs before the truck gets into boost. There is a general accelleration lag from a stop as well. note:my idle is good.and when i'm in boost it runs silky smooth with little knock.
mods> ported vortecs/portedintakes/built bottom end/412/50lbers/250 walbro/AFPR/ultimate for 50's/Deltagate/20G/
my ignition is soild>new dist/msd wires/..tried many different plugs and gaps with no success..i'm using autolites now...note;yes my timing is on TDC
I've tried adjusting my fuel pressure to both extremes with no luck.
And tried different settings on the ultimate
new vac lines...and all my sensors are new>
Real Question>>
That piece of paper that comes with the ultimate says that the chip only affects timming and fueling under boosted conditions....Hmmmmmm so if Syty stock chips run lean at idle... Mabey my engine is running even leaner with my higher flowing heads and cam. It sounds strange to have a chip that only has an effect under 50%{if that}of normal driving. I could drive around all day without getting into boost....Am i missing something here or doesn't it sound wierd to have a chip with that kind of drivability?
I'm going to put it on datamaster....What are some things I should look for?
one more> How does the vac test{innertube on IC}work...wouldn't the air just leak out through some of the valves that are open?
later,
malik
Sy769
With a new build like that the first thing you should do is use Datamaster.
Sounds like you have a off idle stumble.
The popping could be a exhaust leak.
Do you understand all the settings on the 50 ultimate?
If you have the version for a basically stock motor it will never be right with your combo. There are other versions for vortecs and different cams.
Stray far from the combo used to calibrate the chip on a speed density system and it will be off.
tealty
Malik,
In my car with vortecs and 50#injectors and a 76bb turbo, the only program that will work is the f7 table. Every other table will give me a lean backfire. People riding behind say it shoots a pretty good flame out the back. So I just ride on t2f7.
On a side note, does anyone know where they stopped tuning in rpm's on the 50# ultimate chip for heads/cam? It seems to me like it stops in around 5200rpms.
Later
Jordan
Mkid
Thanks for your input guys,
I got some bigger problems to deal with now>
driving around today at about 35-40mph and the truck starts to stutter heavily and begins make a heaving pinking sound....like someone threw some nickels in 1 or more of the cyclinders. VERY VERY bad sound....this is very strange since my motor has about 1k miles on it and hasn't seen more than 8lbs of boost......anyway, once i fix it I'm deffenetly going with a custom chip.
later
velox03
well as far as not getting more than 8lbs of boost check if your cat converter is plugged. i had this problem and then the shop took of the cat and it got full boost... replaced the cat and now i can hit 15lbs...
however, on a side note... now i think i'm overboosting. i got on it WOT, and then it felt like i hit a brick wall. then the check-engine light came on. i saw a post by jimmy regarding this, but haven't found one saying what the problem is... the shop did put a 3" cat on, would this be too large?
-MikeC
SeattleSy#1255
Category 5 Conservative
man, are you sure your timing is right? Explain how you did this.
verified you have a 3 bar MAP?
i know they are basic but sometimes its that simple
