engine harness question
blk00z28
Forced to by choice
For those of you who have moved the engine harnes from over the top of the brake booster to under it. How did you deal with the harness plugging into the block on the firewall being pointed up rather then down?
What I'm saying is if I put the harness under it, it'll make the harness loop and have to do a 180 to run that way.
Any help, with pictures would be awesome. ;)
blk00z28
Forced to by choice
Re: engine harness question
Thanks for the bump. No one has talked about this yet. Everyone I've talked to switched to hydroboost and wouldn't have this problem.
hardtailcfl
I know it....I've searched and searched but found nothing. It will make an already cluttered engine bay SO MUCH CLEANER by doing this!
blk00z28
Forced to by choice
Bump.. Someone has to have a idea how to do this without zip tying it up then back down.
blk00z28
Forced to by choice
Can you host it somewhere else, it says I have to log in to view it and I'm not a member of that.
nallj92
yeah ill re link it......LINKED again, also i plan to try to clean the area up again so you dont see those wires, that was just a temp solution for now, if you unloom the area you could possibly bend them tighter, then loom it up with new loom, would look alright
blk00z28
Forced to by choice
Thanks for the relink.
Anyone else have any more options for this other then bending the wires?
s_blazin
ok what does the hydro boost do? i've owned big lifted chevys with it hooked up to the power steering and obviously brakes but never really figured out why it was added
I just piled even more stuff on top of the booster, keeping the mess together. :rotf:
blk00z28
Forced to by choice
Blazin, switching to hydroboost helps hold more brake pressure for a boost launch. My reference to it was its easier and wouldn't look as bad with the wires going over the top of that then the stock booster.
sy#2716
SyTy 4 Life
Hey send me a message tonight and I will get some pics of mine and send them too you. I have to take the truck back down to the shop to tightend up some stuff and get rid of an oil leak.
