engine help
syty9933
im doing my compression test tommorw but i remember this felt like it started wheni took my valve covers off and when i put them back on at idle it made a clicking noise, so i turned the valve cover around it is was fixed, is it possible i knocked somthing off adjustment while putting on a valve cover?
KDBL1TY
Re: engine help
Your rockers and valves should not be making any contact unless they are aftermarket roller rockers
syty9933
Re: engine help
they arent but it did , i fixed it immediatly and its fine , i was just wondering if that 15 seconds of hitting couldve messed with somthing
BoostedSUV
Re: engine help
i doubt it... you just heard the noise of the rockers touching the valve covers because they were on wrong. I highly doubt that would knock them out of adjustment
