procket2_8
What engine management do you guys run or recommend?
Also where should I look for head gaskets, Gm doesnt produce them anymore, the part number is discontinued...We needed to pull the heads, l;ost compression in one cylinder, ended up having bent valves and a blown HG
Better than replacing the JE pistons that are in there.
What turbos have you guys had the best luck with, I personally like Garrett, but if precision is a nice replacement(bolt in) Id go with that. Im doing a air to air setup as well due to the fact that crappy little air-water thing is garbage and may have caused the valves to get bent from running too lean and too hot.
Thanks!
Thanks!
