Engine Oil Cooler...do I really need one?
MrNurse
i'm no homo
Just courious, I am going to replace my oil cooler with just a oil filter relocation kit due to an oil leak :rant: , and the inability to remove the stock oil cooler adapter due to :roll: ,poor ability I guess :roll: . I can't get a wrench in there that has enough leverage to get it loose :rant: and all I am doing is twisting the stock lines :rant: . any help would make me greatful. :D
QUICK STORM
B.A.M.F. BMW Tech
Re: Engine Oil Cooler...do I really need one?
i want to get a B&M supercooler for an engine oil cooler. what do you mean about you not being able to remove the lines?
RSpengler
Ghetto Fab Specialist.
Could you possible stack two wrenches to get some extra leverage, or not enough room?
-Rob
MrNurse
i'm no homo
I can get my stubby 13mm on the bolt, but the other end is up against the block......no turny..... I tried getting a impact swivel with a swivel head ratchet, there is no room to turn it. the only thing I did not try is a long extension coming from the front of the motor along the oil pan to the 13mm on the manifold to the oil cooler adapter. but even on that I am having a hard time seeing the space for me to get the extension in there. I know what I am going to do, I am going to remove all the stock oil lines and replace them with aftermarket. my question is do I need to have an oil cooler, do I need it now or can I just install the new kit and an oil cooler later, or is the cooler not really all that important on our trucks, mine is nearly completely stock.
jwaller
Evil Genius/SyTy Guru
I ran one of those and it kept the oil too cool.
cloneman315
i got that system from e at turbo time it is sweet and works well
i bought a after market oil filter relocation kit for a Skyline while i was in japan it works great a little difficult to install but i didnt install oil cooler due to my aftermarket radiator dual core race radiator. ive never had any problems yet and its been about a year. the radiator is Great though
here is some pics
http://www.syty.huryde.com/gallery/Pics/aaq
QUICK STORM
B.A.M.F. BMW Tech
ok so a no go on that then, thanks, so i don't have to learn the hardway
QUICK STORM
B.A.M.F. BMW Tech
i just used a long extension with a 13mm, you can get it in there easily, you'll probably need to remove the lower heat exchanger
SacDoug
To answer the original question, on a turbocharged vehicle, yes, you need an oil cooler. Not only is your engine oil being heated up by your engine but it is also flowing through your turbo. Turbos can get extremely hot and some of that heat is transfered to your oil.
You have to keep in mind a few things here:
1. Your oil cools the back of your pistons. This reduces knock.
2. Your oil aids in cooling your turbo.
3. Your oil lubricates your engine and turbo. Cooler oil lubricates better than oil too hot.
4. Cooler oil is less likely to coke up your turbo than hot oil i.e. it will extend the life of your turbo.
5. Oil ran hot all the time breaks down faster and does not last nearly as long as oil ran cooler.
Therefore, I would not recommend running your truck without an oil cooler. You would be adding unnesessary wear on your engine and turbo.
bezerk
syty's have an oilcooler already
jbone
okay... this is true but I dont know if youre telling him it needs another one or the stock one is sufficient. In the book "Maximum Boost" by corky Bell he claims that you dont "need" one and actually they can (like Waller said) make the oil too cold. Most oils are designed to operate most effeciently at certain temps. and adding an oil cooler can make it lower than those temps. .......( I think thats what he said :dunno: ) but you do bring up very good points :tup:
SacDoug
In the original post he asks if he can just remove the stock oil cooler and run without it. My response is to the original post. As I stated in my post, it is a bad idea to run without an oil cooler.
I have not read Corky Bell's book but I don't think you can take a general statement like that and apply it to every vehicle. The proper way to determine if your vehicle needs a oil cooler or not is to take oil temps during hard driving. My other car is a twin turbo Dodge Stealth. Upgrading the oil cooler significantly reduces knock because there are oil squirters that shoot oil on the back of the pistons at higher rpms. There is no worry about cooling the oil too much because there is a temperature sensitive control valve in the oil housing that controls oil flow to the oil cooler. The hotter the oil, the more flow goes to the cooler. Corky Bell's statement is clearly wrong if you try to apply it to that car. I do not know if a SyTy has a temperature sensitive proportioning valve like that but automotive engineers put oil coolers on vehicles for a reason. Trust me, they try to cut costs at every chance they get. If they could save $150 per vehicle by not installing an oil cooler, they would.
jbone
I didnt say it wasnt needed, and neither did Mr. Bell simply put too much oil cooling is a bad thing but I understand what you are saying since you repsonded to the question of not running an oil cooler at all.
SacDoug
That is not the impression that your post gave.
Adding a cooler sounds like the vehicle does not have one to begin with. Also, stating that doing so would lower the oil temps below optimal temps makes it sound like it is a better idea to run without an oil cooler.
I may be over reading your post and I have a bad habit of doing that. I am glad that you are not advocating running a truck without an oil cooler.
MrNurse
i'm no homo
ok, so I need an oil cooler, would one of those frame mount ones be enough, I think they are actually trans coolers, would they flow enough, I am wanting to eleminate some of the stuff under the hood. the frame mount one is the tube like one that I think is or was going on the "syborg" truck.
jbone
I hear a lot of people go with a B&M oil/tranny cooler. that should do.
