Brwndrvr05
I just completed a stock rebuild on the 93TY 4.3 V6 and im not getting the results im use to seeing during the engine oil priming stage. I have got the both driver, passenger side valve covers off. The motor is pretty much completely assembled minus the upper intake manifold. I have a chevy priming tool which consists of a shaft and two collars. Im using a straight 30 weight non detergent oil during this process and for the break in period. I have been priming the engine for a few hours at 10-15 minuets at a time and im not getting the results that im use to seeing with other engine builds that i have done in the past (Ford engines). During the priming i have oil coming up the more on the driver side and very lil to near nothing on the passenger side. My problem and question is that it take a really long while for the oil to come and it seems that the volume of the oil is just really not there. Is this normal or am i doing something wrong? I have primed several Ford engines and oil comes up instantly and with lots of volume. Note: when im priming the V6 im turning the crank slightly to rotate the rockers to see if oil will come up better or faster. I have the oil lines hooked up going from the block and instead of going to the remote filter i have them dumping back into the head, and the volume and pressure coming from these lines are outstanding, lots of pressure and volume. I would like to know from you guys that have experience if this is normal or am i missing something here? Once again i have very lil volume just seeping out the driver side pushrods and near nothing on passenger side. Let me know what you guys think, Thanks
