Engine pics with Edelbrock lower intake, DONE!!!!
ticlone
Esss in the house!
Are those Vortec heads? And do they match with the intake without having to mod the intake?
BigAl...
Nice job on routing the pipes. Looks good! BTW the elbow is sold by PTE and Wilson Manifolds and they come in 90deg and 110deg and I want to say there about $200.
BigAl...
nastety92
As BigAl said the elbow is from PTE, mine is a 110* and I have a 90mm throttle body on it, also purchased from PTE. The good thing about the work on the intake was that he was able to use the stock throttle linkage and hardware. They are stock vortec heads that bolt directly up to that lower intake. That is the reason I went with this set up over a stock setup that the lower intake had to be modified. I also really like how it all goes towards the drivers side and everything is away from the turbo. Once the weather gets nice again it's going back to get dyno'd again with the T-63 turbo thats on it and we are going to see how much power this thing will make. Thanks for the good comments
Lata,
Nick
nastety92
All the wires were either extended, re-routed, and replaced. It's all still there but we had to use a IAC sensor now with this new throttle body. It's kind of hard to tune, but not to bad.
Nick
ticlone
Esss in the house!
Nick keep us informed! Who knows you may have started a new SyTy trend! Well new to me!
What did you find was/is the most challenging part of this mod?
Did everything bolt up pretty clean?
From what I see its a Edelbrock intake, elbow, new throttle body, A2A and vaccum lines. It seems that thottle body linkage being able to be reused is a plus.
nastety92
The hardest part was re-routing and changing all of the ports where all of the sensors go. The upper and lower intake were both set up for a carburated motor, we had to make new fuel rail, bungs for the injectors, and make all brackets for the throttle cables to go into the intakes. I think it's a very clean upgrade, I really like what it does to the engine bay, I also like how it keep the A/A IC away from the turbo now. I also think it's a huge plus to be able to bolt on the vortec heads.
Thanks for the positive feedback,
Lata,
Nick
