engine pulling question (short)
bezerk
So i'am pulling the engine, and i hope to get it out on saturday.
So now i''am with clean hands trying to spare myselve some work.
How should i dissconnect the engine-rubbers????
on the chassis, or is there enough room to the 1 bolt solution??
Thanks already (again and again)
Will be tying sooon!!!!!!!!
Rene
sytyguy
Moderated User
Have someone (or you if you're stretch-armstrong) hold the front side still with a wrench and you zap it loose from the the rear with an impact. Install same way.
Michael
heavy breather
FBI enforcer
You may get lucky enough that a strong impact will ake the bolt out without a wrench on the other side. Keep your fingers crossed!
Put a ratchet on it, rest it against the frame/block and get the bolt side with an impact.
ed hess
race or get outta the way
lay under truck for dr side
box wrench in left hand, ratchet in left, legs pointing to pass side.
bend heat shield up a tad to get box on.
remove bolt.
this is all i did. took me a few minutes to find other end of bolt concealed by heat shield. felt stupid after that.
repeat on pass side...
or did i miss somthing here.
ed
Sy#26
You talking about the engine mounts? After disassembly, tack weld the nuts to the mounts, centered in the adjustment slots. You can then do the R&R job alone next time, just putting the bolts in from the rear. Hummm, and there *always* seems to be a "next time.....".
bezerk
Thanx guys
i thought if you just go for the one bolt solution, the motor would get stucked when lifting.
But no propblemo.
Engine is out, and cleaned everything.
To bad i can't post pictures, because i found a STRANGE serial ENGINE-Code
Does somebody know this Code??
10066061 (from out of my head, but normal the last engine code is 11 for syty engineS??????
Rene
