Lynn D. Brown
Hey Guys, Some Q on reassembling engine - probably won't be the last ones :
1.) Oil P Sensor.- My old pictures show the old stock (broken) sensor mounted to a 90° brass fitting screwed into a hole in the top of the block right next to the Distributor. The replacement sensor from GM has different threads and is meant to screw into the block directly w/o the 90° fitting. So it will be sitting vertically instead of horizontally w the stock one. Anyone else see this ?
2.) Guys who installed MSD - The stock coil is riveted to a bracket bolted to the Int. Man. Did U chisel off those rivets to install the MSD coil to the same bracket ?
3.) Did your MSD Coil/Dist spark lead fit tight ? - mine doesn't.
