Re: engine rebuild help
what's happening now, block crank rods pistons all being Cryogeniced,
bolck 4 bolt main, decked
rods are Eagle forged H-beam - Je forged pistons all sharp edges cut down, -top and sides of pistons coated,
( oil sqirters being installed to spray oil on bottom of pistons, )
high vol, oil pump welded pick up tube.
oil pan is bigger 2 more qts, and a plash shield being installed.
new dipstick location
vortach heads ported coated, and custom intake to bolt on the heads.
50lb inje
custom cam
roller rockers
balunced
Garret turbocharger Gt3582 ???
new down pipe with belt in waste gate
2800 stall conv,
wide band commander
mega squrit
?? what head gaskets and is there anything i should add or do or not do .????????
thanks for any and all help.
