Engine rebuild kit
Ty#0318
Where can I find engine rebuild kit for my Typhoon?
Third cylinder compression is poor so finally decided to do this.
Factory and forged parts, please.
autoaddictions
Re: Engine rebuild kit
Sounds like your going to need machining anyway ! Just have the machine shop order you pistons, rods and bearings ect. Save you lots of time and aggravation. Eagle makes good rods JE or Diamond pistons seem to be the most common. Most engine builders will have access to these type of parts.
Thing is your not going to know what size pistons you're going to need until the engine is gone through and checked. Better to have the pros do this so you're not wasting money on the wrong parts..
Z SKI
Thing is your not going to know what size pistons your going to need until the engine is gone threw and checked. Better to have the pros do this so your not wasting money on the wrong parts..
Great advise!!! Do what this dude says... He has a couple fast trucks :thumbsup:
wildphil
I Love My Ty's
I just noticed you are in Poland. I don't know how many Typhoons your machinist has worked on. Most likely not very many.
If that is the case. You would probably be better off having the machine work done. Then post here on SyTy what your engine bore size comes out and what size bearings you need. And we can help you look up part numbers.
