Engine Removal Amateur Style *update*
TurboManiacal
I feel more of a man now. I have removed hood, bumper cover, radiator, grill, various electrical wires, IC System, battery, battery tray, drained all kinds of fluids, annotated many many points for improvement or replacement items that the germans f*cked up when converting to german specs and trying to do engine swap w/ german tools.
Renz was right...if you want to send your SyTy on a diet....clean out all that dirt & grime in your truck! Pics to follow.
Now if only I could remember where everything goes when it goes back together. :drinking:
RARE_TY
I had to start taking a digital photo of evertyhing on the TY before I started taking things appart. Makes a big difference when you go to put things back together!!!
ed hess
race or get outta the way
ryan
use lots of boxes, each item gets its own box. also lots of zip up freezer bags. All bolts go into a labled bag per component. nice neat and organized and then you dont have to remember anything.
I dare you to put all the nuts and bolts into a big pile! :D
ed
hamrhead
Yeah, when we yanked my motor we used a large plastic tray with a bunch of smaller, individual compartments to keep the bolts 'n nutz seperated. Also placed small pieces of paper in each and wrote on them what/where each part was for. Took some masking tape and marked all vacuum and electrical lines as well. Made things go back together much smoother.
TurboManiacal
Ehhh thus far it's going well. The only two bolts I can't seem to find are the ones that are holding hte front clip in. I don't think I'll need those running the autobahn.
For an amateur...it's going real well. Pics in 5.
TurboManiacal
jwaller
Evil Genius/SyTy Guru
why the hell are you pulling the front clip and bumper and all that crap I thought you were just swapping the motor.
TurboManiacal
Loeryder said:
Looks like fun...
Whose shop are you using?
I'm using the Autoskills center on post. 3 trained ASE mechanics on duty all the time with a full complement of tools. While not SyTy gods, they are mechanics none the less that understand how to turn a wrench. Today I had one who'd come by tell me what to take off next and help me with tool selection sometimes...It's been an Eye opener.
TurboManiacal
You didn't teach me well enough on your Ty Obi-wan! I keep trying to think back to when I was over at your place...and this is nothing like it...I'm learning alot though and the real test comes when it's time to put back together tommorrow.
Question: Trans out with the Engine? The mechanic was leaning towards yes till he saw the AWD. Now he says he'd rather wrangle with it on the lift later on. I didn't have the heart to tell him that we'd be using JS Mounts with Poly pads to make it all the harder.
myclone
If it were me Id leave the trans in. Its just as easy to yank the converter and replace the front seal on the trans with it still in the truck (I think I put a new front seal in the crate) than to wrestle the whole assembly out of the truck IMO.
FYI, dunno if I mentioned this before but the heat sheilds I made you are gonna need some tweaking to fit the aftermarket mounts. I made them to fit the stockers as thats what I had on hand.
HTH
myclone
ed hess said:
do you need heat shields on the poly mounts?
ed
Id guess yes on that as Ive seen one pic on here a while back of a partialy(sp?) melted drivers side poly mount from using no heat sheild. Dunno if they had headers or stock exhaust though. Better safe than sorry is the way I look at using them since the mounts are such a PIA to change if one melts.
Syclone#892
I would not even think of pulling the trans way to much work, I would recommend removing the 2 front cab mounts and jacking up the body some. I have heard some people doing this and wish I would have because with bad motor mounts that shifted the engine just enough it was a big pain in the ass removing the bolts.
I have a few pics of some myclone made heat shields that required some tweaking if your interested. The drivers side was perfect except the notch for the thru bolt needs to be a bit taller but I have not put the header on yet so I don't know if it will need a little tweaking there. Pass side was not hard to modify at all just bend it flat again and bent it at a different spot then opened the holes up some and I had to remove some material from the back because it hit the header just a little. I am using atr headers though and I don't know if you will have problems with the stock manifolds or not.
Are you pulling the core support? I think there are 5 bolts per side, 1 on top, 2 from the front one is holding the cladding, 1 from the inside that attaches to the fender and I think 1 from below then you have to pry the fenders enough to get room to get it out. You also have to remove all the wiring that loops through it which would make me say its not worth it if your just doing the engine. I removed mine because I am planning on putting engine/trans in together.
About the only suggestion I have it to watch out for the fuel supply line that attaches to the rail, it will be tricky but you can bend it a little to get some room. If you end up screwing it up though I have the one off my truck you can have if you need it.
Oh about the only other thing I would suggest is to leave as much on the engine as possible because its easier to swap on a stand than in the truck. I will have headers and all brackets and power steering pump on when I put the motor in. You must remove the power steering pulley to access the bolts for the pump so you can access a bolt for alt bracket, you will know what I mean when you get there. Good luck you should have to many problems
TurboTony
Heat shields are mandatory with poly mounts.
The first time I installed the poly mounts on my truck the RR instructions said they were optional. Since mine were kinda ratty I just left them out. When I pulled the motor again to do the big build they were melted.
I ended up cleaning up the mount shields and redoing the heat insulation, etc. So far so good, no melted mounts.
HTH
Tony
