Engine runs strange after replacing heater core
I recently finished a stock (except for an adjustable FPR and MSD coil and billet distributor) engine rebuild on my syclone . Put about 600 mi on it then had to place the heater core. The engine ran fine until I did the heater. Now it runs strange. It idles OK but is sluggish when accelerating. It usuaslly takes about 5lbs of boost to get it to going but it acts like it's running at less than 5 inches of vacuum. But occasionally that same 5psi acts like boost again. I have an autometer mechanical vac/boost gauge, so I'm fairly confident about the readings. It has briefly thrown a hard code 23 (low air charge temp) and code 42 (EST circuit),they don't come on all the time go out when I restart the truck. Also the exhaust downpipe appears to be very hot, it's melting some wire loom near the coolant overflow bottle that wasn't melted before.
Anyone have any idea what might cause this or know of any good tuners around or near Cincinnati.
Thanks,
Craig
Daryl H
Re: Engine runs strange after replacing heater core
Did the heater core leak into the cab?
Check the brown wire for the ESD circuit behind the carpet where the passenger's feet are.
Make sure all of the plugs are on tight on the ECM.
I finally got a chance to pull the ECM and clean the plug ins with electronics cleaner and still have the same problems. The set timing disconnect is still tight and no coolant leaked into the cab. Could it be as simple as bad gas? Or do I need to look into pulling the MSD distributor and replace it with the old stocker.
Thanks
Craig
Daryl H
If your observation with the exhaust is correct then I would bet there is an issue with your timing being off dumping gas into the exhaust. Maybe the AFPR diaphragm is broke allowing gas into the vacuum system also.
Thanks Daryl. It turned out it was timing. I replaced the MSD billet with the old stocker and it runs fine again.
