Engine still stumbles after tune-up
Dr.Evil
Addicted to Boost
I just installed a new cap, rotor, black beauty wires and NGK plugs hoping it would fix my stumble off idle, but it didn't. The truck also takes quite a few cranks to start up when cold, and the idle kind of bounces +/- 50RPM (not smooth like on my SHO). Im just wondering what I should check/replace now that the ignition is not the problem. Maybe the coil? Any help would be great.
thanks.
TYTILIDIE
METH HEAD
Did you check your vac lines? I met a guy this weekend up in Brighton CO that had some pretty bad vac issues. We got em fixed up and its doing much better. Thats what I would check if your stumbling or stalling. Also make sure you have straight boots on #1 and #6. Make sure your wires arent touching anything.
Mike
Captain Morgan
Moderated User
make sure the wires arent crossed too.
I occationally do it when im rushing and when I was rebuilding my '92, i crossed 3 wires on the pass side and it started and idled fine it just had no power, took like a week and numerous members trying to figure out what it was cause I thought all the wires were right since it didnt show any normal signs of crossed wires :lol:
Ian Turgeon
Cascading Inspiration
I think I'm concervitive in saying that 90% of these trucks idle with a 25-75 rpm stumble, especially when warm.
Dr.Evil
Addicted to Boost
Thanks for the tips.
Im going to yank the Iridum NGk plugs and try the UR5's. I'll also check the wires.
Does anyone have a vaccum line diagram? Also, the P/O hooked up a boost guage which taps into the brake bolster line...could this be a problem?
93 Ty
Mike, thanks for the help. Hey I just bought a shurflo pump. Guess what I will be doing these couple of weekends :rock:
Dr. Evil, don't mean to hijack your thread
SY2455
70's Veteran
That connection is for hot water preheat, thats not use in our application. Use on some Z-28 & Trans Am.
SY2455
70's Veteran
I would not change out your plugs, I don't think that is your problem.
I never heard of tapping the brake booster line for a boost gauge. I would locate a new place. Like tapping off the line to the MAP Sensor.
SY2455
70's Veteran
Re: Engine still stumbles after tune-up
thanks.
This is what my truck idle at. If you are running the stock chip, I understand it the factory program.
sytyguy
Moderated User
Actually Lloyd, the booster line is the most common and recommended place for a boost signal. I have seen problems from tapping into the MAP sensor line due to pressurizing an additional 4' or so of line and a gauge. The quality of the reading (both to the gauge and sensor) comes into question when tapped into the MAP sensor vac line. This was the cause of off readings (from DM to gauge) or more than one truck that I've worked on.
Hood
denny
This is not a problem, I have mines there over 5 years now.
Denny
ty 369 12.5 @ 108
SY2455
70's Veteran
Hood
Thank You. I learn something new today.
GM TURBO
Sell Out
Two things - I agree with Hood on the boost signal at the brake booster - best easiest solution. In fact there is a kit sold at www.autoperformanceengineering.com just for this reason.
Now - back to your truck idle madness...
I'd say replace the fuel filter. Whenever I've had issues with slow starts this is almost always the case. The other is when the fuel pump is dying. Filter is cheaper and easier. And if it doesn't fix it you know you can rule it out during your next driveability problem (which will happen :) )
Dr.Evil
Addicted to Boost
Well I just checked all the vac lines I could see and didn't find any cracks. I have a 255 Fuel pump that is going in when I install the Ultimate. On a side note, the Ultimate that came with it says its for a 92 and I have a 93...will it still work or do I have to swap to a 92 computer...?
Also, I have a feeling my Ty is a bit down on power. I raced a friends 1995 z28 w/ and intake and borla catback, and he pulled on me pretty good. I had him from the start, but he caught up real fast and beat me by about 2 cars up to 90 or so. I launched at about 2psi (I couldn't hold it from rolling while building up the boost) so maybe that is why I lost...? From what I have been reading, a stock Ty should not have much of a problem w/ an SS let along a z28. Anything besides the vac lines and ignition stuff cause poor performance? I am boosting 15psi @ WOT so I don't think its turbo related.
One thing I noticed when I got the truck is that there was no fluid in the upper IC. I drained what little was in there and filled it back up. With the pump on, I can hear it pumping fluid, then I can hear it go dry for a bit, then it will start pumping again.
The previous owner replaced one of the hard IC lines w/ heater hose. The line goes above the highest point on the IC. Could there be a problem with an air pocket getting stuck in there causing it not to flow?
Any other ideas would be great...I cant wait for a rematch w/ the z28 :rock:
TYTILIDIE
METH HEAD
Let me know if you need any help Ill be up there Sunday probably. Got my tires today so all is well with the TY. Sorry Dr. Evil...Steve started it.
:lol:
Mike
Dr.Evil
Addicted to Boost
Well this weekend I replaced the fuel filter and checked the compression. I got 135 to all 150 in all 6. My Ty has 106k on the original motor. It still takes 8-12 cranks to start when cold. Also still seems sluggish. Fuel pump is next, what else should I try?
#2875
built, not bought
do you have an adjustable fuel regulator?
Dr.Evil
Addicted to Boost
I have one thats not installed yet. Its going in when the FP goes in. Does anyone happen to have install instructions for a AFPR?
