engine tec
sean
I'm building a ty motor and would like to know what are the best pistons out there. I'm going to use vortec heads and 412 cams. going to use an up grade turbo and 50# injectors. can anyone help me. and if so where can i get them from. :tup:
Stangbeater
How bout it?
Welcome aboard.
What exactly do you mean best?
Cost effective?
Strongest?
I personaly like the SRP's.
Where are you located at in NY?
nightdiver
JEs for me. We use the in several high hp engines with no problem
You can also get a set from Venolia :tup:
Windedv6
Ty n 10s
SRP's are made by JE. I use them in my Ty and they are holding up fine. You will like them better for street/strip use vs the full race JE which will give you some chatter until they are warmed up (they expand more than the SRP's, thus they need to be clearanced a little more which causes the some piston slap when cold).
John
