Engine tiedown ?
SYO237
SyTy Registry
Re: Engine tiedown ?
So, I am going to install my tie down in my typhoon and I noticed that it will go straight through the two hoses that come from the engine to the oil filter. Is this normal? It seems like that is teh only spot that it will fit to be straight and lined up so it isnt pulling one way or the other.
Does it on my truck. I just bent the power steering hoses out a bit (gently, go slow). I then just put a small piece of rubber hose on the exposed bolt threads to protect it from rubbing.
mcskibadee1
sweet, just installed it that way and fit great. I cant believe that that screw into the frame is enough to hold.
