Engine timing @ idle & @ 2500 RPM
It's just a six
Super Member
Hey guys,
I am curious as to what the engine timing is set to stock from the factory @ idle & @ 2500 RPM?
Also, when the tan wire w/black stripe is unplugged, how much timing does it remove @ those RPMs?
For smog tuning purposes
Thanks:tup:
TYTILIDIE
METH HEAD
Re: Engine timing @ idle & @ 2500 RPM
Hey guys,
Also, when the tan wire w/blue stripe is unplugged, how much timing does it remove @ those RPMs?
Thanks:tup:
my guess would be somewhere around 25*@2500 RPM. When the wire is unplugged you have 0 timing.
It's just a six
Super Member
Thanks.
I set the timing to 0 degrees,(tan wire w/black stripe) unplugged, then w/tan wire w/black stripe plugged back in the timing is above the scale guesstimating about 15-16 degrees timing @ idle.
Anyone else know what the timing is @ 2500 for stock timing table w/the tan wire w/black stripe unplugged?
BoostedSUV
With the tan wire unplugged the timing will be 0 no matter what RPM... With the wire unplugged ECM timing control is taken away and the timing will "default" to 0
TYTILIDIE
METH HEAD
Right. Like I said, you have no timing with the tan wire disconnected. Idle isn't 2500 RPM either. So are we really asking what timing should be in park revving it up to 2500 RPM? If so, what is your MAP at at that RPM, I can look it up in my stock timing table.
bonesdmz
In Mother Russia Typhoon drives You!
Few months ago we checked timing at my buddy's TBI s-10, and there was actually some timing advance even with tan wire disconnected. It was 0 degrees at idle, but once we started revving it up timing mark advanced to smth like 15 degrees, starting from 2000-smth rpms. It was 0 or 15, nothing else. Maybe there is some backup system...
